window wiper wiring..?
Started by apmaman, July 02, 2013, 05:20:33 PM
apmaman
1962 Volksrod
hi folks.
im following peters diagram for wiring and iv come to installing the wiper motor and switch.
my wiper motor looks like this. it has not got pole 30 for power. it has 53a 31b 53 53b and 31 under the white tab.
my switch is an iva rocker from cbs. has 4 poles.
im a bit stuck as i dont want to burn anything out testing it.
Doon SWB No.1 & No.2
Hi Buddy,
Do you have instructions for the switch? If so I may be able to help.
Basically you will only be using 3 or 4 of the pins on the wiper motor.
apmaman
1962 Volksrod
no i dont unfortunatly but i will email cbs
online just encase they do.
i think the switch is an off on on but thats just a guess.
parmaynu
Nuffin
Do you have the CBS catalogue? It has a diagram in there.
Old Skool Parts Shop
oldskoolpartsshop.com
apmaman
1962 Volksrod
life saver!!!
cheers!
apmaman
1962 Volksrod
i missed the edit post timer but from that i guess...
1 - park 4 - low speed 5 - high speed?
Hi Buddy,
Sorry I forgot I said I would help with this.
Try this layout out,
Basically you will only be using position 1 and 2 on the switch
It appears than point 2 on teh switch is the common feed on both positions 1 and 2
so
12v +ve feed to pin 2
Pin 1 to 53 on Wiper Motor (slow speed)
Pin 4 to 53b on Wiper motor (fast speed)
-ve (earth) to 31 on wiper motor
and finally
take an additional loop feed wire from pins 2 to 53a on the wiper motor which is the self park feed (sometimes works, sometimes not, depending on the wiper motor)
try this simple wiring out using the battery first and should all work. (fingers crossed :))
apmaman
1962 Volksrod
awesome!
ill give it a whizz as its much simpler than what ive got at the moment.  ;-)up
