A Frame
Started by CHARLIE-DONT-SURF, May 18, 2026, 09:34:57 PM
CHARLIE-DONT-SURF
A Frame for sale. Have the two cables that hook up into the front drums.
 Collection from Exeter or happy for you to arrange a courier to collect.
£150
Curious   ???
How do those cables connect to the drums and how does that work?  Not seen that setup before  :-\
I`m baffled as well. Are you sure they do not connect to the brake pedal or the rear drum handbrake cables ?
Is it just designed to look a bit like a braked A frame?  :-\
CHARLIE-DONT-SURF
I have absolutely no idea chaps.
  It came with a pile of parts with mine and was told the cables fit in the front drums of a fashion.
 I don't know how/where etc.
   Just going by what I was told.
Carry on normal jogging chaps  ;-)up
just needs the 2" hitch cut off and a overrun 50mm hitch fitted then you can make a legal  A frame that operates the buggy brakes has a working hand brake and applies the brakes if it comes off the tow hook.
