Got a strange one.
Started by Doon L001, January 30, 2026, 12:28:36 PM
Quote from: Paul1953 on May 14, 2026, 02:22:48 PMWow..   100% baffled.... How can anyone like Haynes state the engine is complex. It could not be more basic.
👍👍👍old school motors are simple machines unlike the modern variable vale timing engines and stuff around these days.
Best go with Rob and watch a strip down of the motor the only awkward reassembly bits are the cam followers dropping out as you lower the top case on but a bit of grease will hold them in if you do not have the spring clips.
They meant more complex to dismantle i think. Old Ford engines stayed on the engine stand.
Head off,  turn engine over, sump off, remove internals.
Can't do that on a beetle
