parts wanted
Started by bulliporker, September 05, 2025, 12:27:30 PM
bulliporker
bugle
   metal  cover for tunnel   over gear shifter plate,   front   gearbox drop down plate , solid  rear gearbox mount, mountey  steering   wheel boss,
Quote from: bulliporker on September 05, 2025, 12:27:30 PMmetal  cover for tunnel   over gear shifter plate,   front   gearbox drop down plate , solid  rear gearbox mount, mountey  steering   wheel boss,
I've got the boss depending on what size spline
bulliporker
bugle
is the later  steering  column larger or smaller than the early  one do you know
Pre 1960, 1960 to 1973 1/2, 1974 onwards.
bulliporker
bugle
thats very  usefull david thanks
bulliporker
bugle
do you know which  one you have chris    is it complete with the plastic  horn push
Quote from: bulliporker on September 17, 2025, 10:55:44 AMdo you know which  one you have chris    is it complete with the plastic  horn push
I've been to find it but its nowhere to be seen, I can't remember selling it but must have  :-\
bulliporker
bugle
no worries  chris   if it turns up later let me   know
#8
I've got one of you're stuck.
Will swap for LHD Pitman arm, a Beetle/Camper hazard light switch, a steering box clamp, an inner track rod end with the eye for the steering damper or a couple of quid in an RNLI collection box to cover postage.
bulliporker
bugle
you got an early  mountey steering wheel boss david
#10
60 to 73 style. Will swap for anything on my wanted list above or a donation for postage.
bulliporker
bugle
     dave    will have to have a look what i have
 ;-)up  ;-)up  ;-)up
bulliporker
bugle
had a look dave  cant find anything on your list   besides a iluminated switch but dont think   its genuine vw  please let me know what you want  postage  unless there anything else your looking for
I'll get a price for postage later.
