Adjustable tank neck and manx screen mounts
Started by Chris M, February 19, 2025, 04:29:57 PM
As title:
I'm looking for the adjustable fuel tank neck that used to be sold by old skool parts shop and a pair of manx screen mounts that slide inside the frame so invisible fixing.
Anyone have either or both kicking about?
The old skool parts filler and neck were copies of flatlands engineering parts. Mathew started selling them when Mark gave up offering buggy stuff. The filler cap and neck are available from the likes of car builders etc.
The screen mounts are just bits of plate with two holes in them. You could knock up a pair in minutes.
Quote from: Paul1953 on February 20, 2025, 07:44:47 AM
Thanks Paul, i've been speaking to Mathew and i've bought the screen mounts as by the time i've bought the rod, nuts, washers and the bar plus making them its not far off what i paid for them.
The filler neck he hasn't got anymore and i've had a look on Car Builders but not convinced with it. I'll just do what i did last time and cut the standard neck off and weld it where i need it and use flexi pipe to a aero funnel filler
