Distributor needed please
Started by K70, July 14, 2024, 03:33:43 PM
K70
Type 4 bosch OE distributor NOS hall type ~
(071 905 205 /0237023007)
Or bosch hall sender /rebuild kit.
Consider NOS Bosch 050 with points.
Also scrap EMPI 2 tip type 4 exhaust {to copy /cut bits off}.
Type 4 j-tubes.
I might have one, I'll check for you later
Hiya, yes I have found one if you are still after one. This is the one with the double advance can! £60 posted, if that is any good to you
K70
Where can it be collected from pls?
Shows etc?
