im new to this and alas i need help
Started by Johnno62, June 18, 2023, 04:57:57 PM
Johnno62
hi guys im new to this and need help in the parts department. i dont know how to start this or even if im in the right depart ment. im after a seal which fitted to a buggy front windscreen, this is the seal that is attached under the windscreen frame and sits on top of the bonnet. without this i have a gap where when raining comes under frame and into the car..    pls can someone help me find a new one and where from. many regards. james
Hi James.
It ultimately doesn't much matter too much where you post except you might get more attention in 'Buggy General help' or 'Buggy Body...'
Window seal questions come up periodically and there are suppliers as well as bathroom seals that work - someone will come along and give a steer but mean times you can Search 'Trim' or 'Seals' and there are many threads that might have the answers you need.
If you can post a snap of what your existing set up /gap is that might help - see blue link below this box.
We always welcome images of buggys, or bits of buggys to whet the appetite !
As Paul days Woolies has a massive range of seals. You're not likely to get an off the shelf part for a buggy. On mine I got a filler strip of dense foam that went under the screen,bjust measured the gap, either work it out or stick a bit of plasticine or similar under it and  put the screen back then measure. Add a couple of mil and Robert's your dad's brother
I think King Fisher Customs sell these!
