IRS conversion jigs
Started by Bondo, June 24, 2021, 11:02:56 PM
Bondo
Hi looking for the jigs to position the IRS brackets for the conversion of my swing axle pan.
The Baja club has one they can be found on FB,
I did one without the correct jig by swapping the complete horns cut above, around and below the torsion tube, with a simple frame bolted to the tube ends around the horns with holes for the large bolts so it was all correct then cut the swings off bolted in the IRS and welded it all up.
