Type 4 flywheel hole plug
Started by Zip Buggy, July 20, 2020, 05:43:24 PM
Zip Buggy
FF Buggy LWB
Would anyone happen to have one (or two as a mate is also after one) of these
The plug goes in the inspection hole for the flywheel on a type 4 - a hole that is of no use unless you have an auto box apparently.
not got one but thinking the holes was used for a timing mark on the flywheel and as part of the basic diagnostics system on some models. A rubber blanking grommet will probably be easier to find
Zip Buggy
FF Buggy LWB
Quote from: snoopy on July 20, 2020, 07:04:53 PM
I would normally Snoopy but the thickness isn't constant so I was hoping to find an original that clips in.
I used a big rubber bung on mine of the correct diameter and cut it down to shape the hole
Zip Buggy
FF Buggy LWB
Quote from: Dave DND on July 20, 2020, 10:59:58 PM
It'd be good to get an original and get 3D printed copies made though
Doon SWB No.1 & No.2
Have you tried Lee at Volksmagic?
