Cleaning Crud off old parts.
Started by dseered, May 13, 2019, 10:48:55 AM
dseered
I am gathering parts for my build, old stuff is obviously very cruddy, with years of grease and road muck - is there an effective cleaner that is helpful at getting off, while being cost effective!
#1
Cup wire brush in a 4 1/4 inch angle grinder does it for me, using the appropriate eye etc protection.
pugwash
Quote from: dseered on May 13, 2019, 10:48:55 AM
Ive found the cheap spray cleaner "elbow grease" does a pretty good job .
dseered
Haha - cheers chaps, I remember my dad used to brush on a liquid and muck just dripped off - thinking about it, it could have been petrol?
Got a wire bush on the electric drill and its doing a decent enough job on the chassis bits, its just the oily damp cruddy front end really.
#4
Your dad will have used Gunk or Jizer degreasers, I'm sure both are still available along with other brands but like most chemicals, probably not as effective as they used to be as chemicals have been made 'safer'. Paraffin and diesel both work well but can be harsh on the skin.
dseered
Cheers @Manxdavid - ordered some Jizer, will see how I get on.
brush or spray the jizer on then wrap the item in a plastic bag so it soaks in rather than drying out, then wash off after a good time soaking.
dseered
Quote from: snoopy on May 13, 2019, 09:40:05 PM
Awesome, thank you!
PhillipM
Comp Safari Rail
I like Surfex HD - seems to work much better than the old stuff, as said above a lot of the old brand names have been neutered these days.
93fxdl
sand rail and manta ray
Washing up liquid is good for killing grease but has salt in it, so needs to be rinsed off thoroughly. For built up crud deposits a pressure washer with a dirtblaster nozzle shifts it, smaller parts can go in the dishwasher
Ttfn Glenn
Mickyb
GP MK2 LWB
Quote from: Manxdavid on May 13, 2019, 12:37:32 PM
A word of warning I use a angle grinder and wire cup sometimes but the last time I did it jumped out of my hand and flew up in the air, It landed on my shirt and the shirt got rapped around the cup and the other end hit me in the head.
I now have a very big graze on my shoulder and a bump on my head. I consider my shelf lucky it could have been worse so please be careful especially when you are near the edge of what ever you are cleaning up.
Jaysons Dad
1961 Beaujangles Can Am
#11
Do not do what my old boss did. He was rebuilding a BSA Thunderbolt which had been standing for years. A good friend of his, also a motorbike restorer, commented how good metal parts became after a cleaning cycle in the dishwasher. A plan was hatched with my boss paying for his wife and friend to go to the threatre. Unbeknown to her and even before the curtain had gone up on Act 1,  the petrol tank and various carburettor bits were on its first cycle (please note the word "first"). When the cycle had finished, my boss opened the door with great expectations of gleaming parts, only to find that all the contents, including the white plastic covered shelving had turned a dirty brown colour  ::) what he had not reckoned on was for the dishwasher tabs to loosen all the crud sitting in the bottom of the petrol tank :-\ Unfotunately the story did not end well, he managed another two cycles before his other half came home (to no avail) and ended up buying a complete new set of dishwasher shelving  :'( the moral of the story is, if you are going to use the dishwasher to clean car parts, pack the other half on a 7 day full board holiday to Greece, because if it does go "tits up", you have got time to sort it out!  ;D
Definitions -
We use to use trichoehlene 111, nearly 40 years ago. Banded now cos it's cancer genie. 😩🥬🙏
We used trich to clean gun parts back in the 80's, it even removed carbon but they rattled a bit the next time you fired them.
Quote from: pepsi81 on July 23, 2019, 08:46:44 PM
Naughty Paul.... "Trich" the most effective cleaner ever. It`s still available. There is a story relating to this solvent....  1st World war..... Naval war ships.... When hit by enemy shells etc and fire broke out and fire extinguishers were present they were found to be unusable... Why.... the sailors had found trich to have the power to remove stains etc from their uniforms with ease. Pinched from the extinguishers for this by unscrewing casing top\bottom... so not reaction of note when the trigger was activated...  Only the British eh ?    ;-)up ;-)up
