Gearbox Shaft length ?
Started by OrangePeel, January 08, 2019, 07:21:02 PM
OrangePeel
Sidewinder (STILL) in progress
Hi, I hope someone can help, the gearbox that came on my chassis has a very long shaft sticking out, compared to other vw gearboxes i have seen. It appears to be connected to diff as wheels and shaft turn when a gear is selected, just wondered if previous owner has connected it wrong, or they made different lengths, can anyone throw any light on this? Thanks, Neil .
postimg.cc/HcPRF5Dt
#1
it has had an alternative engine fitted and the input shaft has been changed to suit it, What is the gearbox code ? it needs the side plate taking off to access the circlip to replace it with a standard one. There are vidoes on you tube and alike with the process.
If your beetle disc goes on it will be for a 411 412 type 4 motor.
OrangePeel
Thanks Snoopy I suspected as No engine fitted, the code on gearbox doesn't give any clues O 236267 stamped on ? Under  The case  Serial 113301103 which is same as a 1300 gearbox I have as spare ,ok will have a go at changing that  tomorrow, :(maybe i wont trip over it again  ;D,cheers ,Neil
