Help with bumper and washers
Started by Jimmy T, November 06, 2018, 04:04:34 PM
Jimmy T
White FF LWB
Hi,
I have a couple of things that you might be able to help me with.
Most off is the placement of the washer bottle. Where do you guys all have yours? Obviously the bonnet is removable and comes with the dash so the switch and the washer jets will come with the bonnet if removed so having the bottle mounted to the car is awkward.
Secondly is the bracing for the bumper I have (pictured below).
If anyone has one I would love to know where you braced it from on either side as the only way I can see is by welding a bracket to the the beam
Jimmy
Raw knuckles and sore knees
Zip Buggy
FF Buggy LWB
My washer bottle sits on the tunnel at the front and yes I welded two brackets to the beam for the front bumper.
your bonnet and dash will not be a simple lift off quick release set up it will require parts disconnecting first  so washer bottle up in the passenger foot well, we have a screw off one made from an aluminium drinking water bottle with the top secured to the tub side or off e bay you can get a washer bottle bag with built in pump, mounting bracket and full wiring kit with switch for about £7.50.
Jimmy T
White FF LWB
Brackets on the beam it is then... shouldn't be hard to sort. Thanks for that.
My fuse box is centre above the firewall so I think I will have my washer somewhere well clear of that :P
Quote from: snoopy on November 06, 2018, 05:50:25 PM
I've managed to keep it all quick release so far with regards to the wiring and the way its mounted.
I'm quickly realising though that the filler cap and washers will be the exception to this.
I already have the parts, so I'll make work what I can.
