Sway Away Bolts
Started by tucker217, September 20, 2018, 11:06:23 AM
tucker217
Sidewinder 'SNORKEL' #1 (The Daddy)
Hi, After Sway Away Bolts, nuts and the angled blocks.  Any Available or does anyone know where I can get them from ?
I may have a block, I'll look later. Grub screws and nuts should be available from a proper fasteners supplier, they're 1/2 inch unf.
I've got everything you need for one adjuster but the adjusting screw has a hex head not an Allen head, it works fine but not quite as neat. PM me your address and I'll send them off.
tucker217
Quote from: Manxdavid on September 20, 2018, 01:31:08 PM
Thanks Dave, Just sent you a PM  :)
They'll be on their way tomorrow. To be honest the block would be easy enough to make if you had one for pattern and a block of ally.
tucker217
Thanks Dave, received them in the post yesterday.  ;-)up
I hope they're OK for you. As I said the screws are standard 1/2 inch unf so should be easily obtained from a proper fastener supplier.
