steering box question
Started by redhouse53, July 30, 2018, 10:35:42 PM
redhouse53
I need to use an '02 steering column on my buggy, but this won't bolt up to a torsion beetle steering box. There are fewer splines and the diameter if the shaft is different.
Does anyone know if I can fit the worm gear from an '02 box into a standard box or am I missing a more obvious fix?
Never used a 1302 column but a welder will be your friend. having u/j's you can dump the flexy coupling and bolt the shaft bottom coupling straight to the box one.
redhouse53
Quote from: snoopy on July 31, 2018, 07:32:24 AM
it's the splines and diameter of the UJ's that don't match the torsion type steering box.
I had considered welding the small splined T piece (that joins the original column to the rubber ring) directly to one end of the UJ shaft but that's a last resort really. Looking for a more "factory" fix
