Bob cat exhaust 4 into 1 pipe
Started by Hugh, July 11, 2018, 09:46:07 AM
Following Snoopy sniffing out the holes in my exhaust pipe I'd like to source another shiny 4 into 1 section to join the 4 exhaust pipes to the silencer.
Doon SWB No.1 & No.2
Hugh,
I have an original tri-mill top piece. Is that what you are after?
Me sniffing out :-\ this is what you get from to much polishing  ;D
Chad sounds interesting. I don't know what a Tri-Mill is but if it's the bit with 4 pipes merging to 1 pipe over about 14 inches and it's shiney then I'm v interested.
I'll ask my Evesham specialist exhaust fitter if a Tri-Mill is the answer.
Thanks.
a trimill has the silencer pointing down to the side using a bend not straight up central like your bobcat.
Ah like Dave C.
Thanks Chad but I'd have to saw off the drooping bit and that would be a shame on a new item.
I'll keep looking for one that keeps the bob cat tail 'up'.
The original Tri-Mill was what the bobcat was modelled on.
It is the piece you are after as it matches your picture (my phone didn't show the picture).
The droopy down one came after.
Ill sort it out for you.
Thanks Chad.
I could buy a whole new bob cat exhaust system for £200/400 but don't think the rest of the system is in need of replacing.
Didn't think I'd find the piece quite so easily and quickly....good old MBC.
