Beach buggy build
Started by Mastertons, May 29, 2014, 02:46:58 PM
Mastertons
Quote from: mm289 on June 03, 2014, 10:40:04 PM
Looks great ;-)up
Is the roll cage bolted to the pan or have you made a perimeter frame that runs ontop of the pan?
Can't tell from the pics  :)
Cheers
MM
Hi it is a perimeter frame that runs on top of the body, it bolts down through the frame the body then the floor pan/chassis.
It has been designed so the roll cage can be easily lifted out.
Hope it makes sense.
