Another selection from the garage clear out.
Started by Buggybaggy, April 08, 2018, 07:20:59 PM
A few more bits and pieces which are taking up room and will never be used by me.
All items are in Leeds.  Prices are mostly quoted with 2nd class postage, but please check individual item descriptions.
Pedal set.  Need a good clean up, rub down, and paint.
What you see is what you get, no brake return spring or rod to brake master cylinder.
£28.00 posted to UK.
Twin port inlet manifold, centre section only.  Heat risers are fairly clear. Clear enough to have a piece for wire passed through.
£18.00 posted to UK.
A pair of J-tubes. Never used or even fitted. They do have surface rust, but nothing major.
£18.00 posted to UK. SOLD
A battery cradle which fits onto the rear torsion tubes, under the buggy tub. (unless you've modified the tub like me and left insufficient room for the battery, d'oh!)
This has been fitted, and the item does bare signs of that.
£23.00 posted to UK. SOLD
Front bumper.
One of the plates which attached to the front beam lower bolts has snapped off, but is present and would require welding back together.
The upper/outer mountings required plates to be welded to the front beam. Those plates are included.
£25.00 COLLECTED from Leeds, or hand over at a show.
A pair of heat exchangers. a bit grubby but in good condition, although I thing the activator levers must be bent - see photo.
They come as seen in the photo,so without the linkage mechanisms.
£30.00 COLLECTED from Leeds, or hand over at a show.
A solid K&L front beam.
£100.00 COLLECTED from Leeds, or hand over at a show. I'll probably be taking this to the SpringDubs show on 14th April.
http://www.beachbuggy.info/Themes/MaterialisticTheme/images/bbc/left.gif
Oojamaflip
Californian
Pm sent
Kango T top
SWB Girlfriend
