A few bits that are missing from the GP boxes
Started by snoopy, February 19, 2018, 09:14:37 AM
A very mixed bag of years on the buggy and most systems have something missing.
Ignition barrel with key or keys 68-72, now sorted
Dual brake resevoir
12mm wide 5 wheel wheel bolts Qty 5
Speedometer and bulb holders
2X Cup bases for the cibie pod head lamps ( any make should do)
Accelerator roller pedal, now sorted
Pair beetle wiper arms and step nuts
Horn push for a mountney type steering wheel 80mm i/dia dish Now sourced
Quote from: snoopy on February 19, 2018, 09:14:37 AM
I have a black plastic one of those Keith - it has a few small marks on it but works fine
Swap it for a cuppa   ;)
Can stick it in teh post if you want to be getting on with things and cross it off the list - or can bring up at NEC   :-\
parmaynu
Nuffin
Quote from: parmaynu on February 19, 2018, 10:42:53 AM
I sell these rollers.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F132406772621
£15 posted to forum members
Cheers Mark will order one in a bit now I have got the 57 pedal set working as it was rusty and seized solid  a far nicer set of kit than the pressed steel later pedals.
parmaynu
Nuffin
Its Matt  ;-)up. Well done getting them freed up. Yes they are the best pedal design by far. I'm getting a batch of them re-bushed next week if that's of any interest.
Old Skool Parts Shop
oldskoolpartsshop.com
Apologies Matt, there is actually very little movement in the pedals but I had to modify a woodruff key as the brake pedal one was missing and mine were all to big width and height wise but a bit of fettling ended up as nice tight fit
