Removing bearings from idf 40
Started by Zip Buggy, October 22, 2017, 10:32:06 PM
Zip Buggy
FF Buggy LWB
Quote from: pepsi81 on October 24, 2017, 07:49:17 PM
Evil bay sells them loose. Space the using a socket/washers as per Flags comment. Using the correct size bolt should compress the rivetnut and hopefully extract the bearing.
Alternatively a collet type of bearing puller(hire/ buy) should do the job.
Just my suggestion  :-\
Thank you for the split collet puller suggestion. I think that's the way to go.
Use collet type of pullers at work to pull small, blind bearings. Definitely work  ;-)up
Zip Buggy
FF Buggy LWB
Quote from: pepsi81 on October 24, 2017, 09:48:47 PM
Need one that does 8mm. Seen a set for 33 quid on fleabay - wonder if it's up to it?
Dave,
That's the sort of kit I'm on about👍
Zip Buggy
FF Buggy LWB
You can expand rivnuts using a long bolt, as I have no photo from the bolt head down. A nut to compress the thing, under that a flat washer or 2 then an oversize nut that does not grip the thread then another washer or 2 then the rivnut. You need to hold the bolt head and larger nut still and turn the top nut down to wind the rivnut up.
Have fitted loads without a tool the smaller they are the easier they crimp.
See Mark, RIVNUTs
Daily Mail will spot this and have them curing disease next
Re your question about the screw removers, I have been away a few days and wrote a long detailed reply on my phone then lost it. In a nutshell they may work on phosphor bronze but not on ball bearings with an inner race that turns.
Main thing to be careful of is smashing them and leaving the outer race in place.  It is made of extremely hard metal pressed into a soft metal so a bugger to break out.  Strongly recommend warming the thing while using the puller (whichever you finally choose)
Good luck
Dave
Zip Buggy
FF Buggy LWB
Quote from: Doon L001 on October 27, 2017, 08:43:13 AM
See Mark, RIVNUTs
Good luck
Dave
I wondered how long it would take you!  ;D ;D
The answer is ridiculously simple and obvious after looking in the book.
You have a spindle and bearing out, so bearing in vice and knock spindle out.
Refit spindle into carb to drive the other bearing out.
You have everything you need to do the job in the carb apart from a vice,  hammer and punch.
Zip Buggy
FF Buggy LWB
Quote from: snoopy on October 31, 2017, 08:54:34 AM
Thanks Snoopy. Anyone want to buy a split collet bearing puller?  :-[
Just unfortunate we were away on a cruise for 2 weeks can you return it as unsuitable and get a refund.
Zip Buggy
FF Buggy LWB
Quote from: snoopy on October 31, 2017, 01:36:42 PM
I'll try. Ebay and I think it came from China  bleugh
Zip Buggy
FF Buggy LWB
Snoopy, as usual you're a star. I hadn't realised there was a shoulder on the spindle until Farmer Rob pointed it out to me when I was there last week. Even then I didn't think of getting the bearing out this way. Worked a treat - one tap of the hammer and out they came!
Also have managed to return the puller - just cost £3 postage. Phew!
That's a pint I owe you :D
Glad to read it worked out well in the end.
