Loose heat riser flange
Started by mad4slalom, October 02, 2017, 09:58:59 AM
mad4slalom
Mk1 manta ray
Hi, just noticed since i fitted new inlet manifold, one of the heat risers was not bolted up , or had vibrated loose. Checked and re tightened both risers and all other exhaust studs a tweak too. Had  been hearing a bit of popping so hoping that was the cause ? 🤔
