swing arm rear suspension bits
Started by Johnthesparky, July 30, 2017, 08:46:29 PM
Johnthesparky
UVA fugitive 4
Hi,
We are after some bits to replace the IRS torsion tubes on the rear of our fugitive, with swing arm bits
We need;
Torsion bars
Swing arm spring plates
End caps (not essential, but somehow cleaning up and reusing is more satisfying than buying new)
fugglededumm
UVA Fugitive
So you are going IRS to Swing Arm - that's unusual.
I am swing arm and have the back end off a 944 turbo to fit ( a pair of mahoosive alloy arms!) and a bus gearbox which will be mated to the MX5 engine - but unfortunately all probably not until the winter.  If you are still in need by then I'll wing the bits your way.
Johnthesparky
UVA fugitive 4
No, just the arms....
On irs, the torsion bars stick out in front of the rear wheels
You can fit swing arm torsion bars, and modify the spring plates to fit and they sit nearly flush like a swing arm model.
http://www.blindchickenracing.com/How_to/IRSconversion/sandrailconvert/sandrail_irs_conversion.htm
You'll need to weld in the front mounts, then swap suspension and gearbox.... this is just an aesthetic thing as we've already got irs
buggypete
can do spring plares and caps and torsion bars.but why would you?swing axle rails handle terrible :-\
Johnthesparky
UVA fugitive 4
Not going to go back to swing axle, just want to get rid of the end of the torsion bars that extend out in front of the wheels.
How much do you want? And where are you? Wondering if collection is possible, I'm in North Bucks
fugglededumm
UVA Fugitive
glad it's not just me that thought you were going back to a swing axle! ;D
Doon SWB No.1 & No.2
I have some spares of both.
Spring plates and torsion bars that is.
My first buggy had modified plates and shorter arms on the IRS to fit bigger tyres, but now running Porsches 944 arms.
I can try and get a price to ship but will be heavy.
I'm in Worcestershire not far from Junction 7 M5 if that helps.
Johnthesparky
UVA fugitive 4
Quote from: Chad on August 01, 2017, 12:47:24 PM
I've sent a message!
