Wanted: A few little engine bits.
Started by Manxdavid, June 16, 2017, 03:36:22 PM
Has anyone got a bottom pulley Woodruff key, bolt & washer, a 100mm fuel pump pushrod and a fuel pump plastic pedestal going begging?
Ta!
Certain I have a crank pulley bolt. Should have the washer too.
Just arrived at work so cannot check just at the moment.
You are welcome to them.
Oooh thanks. PM me how much you want, postage etc.
D Jones, 32 Glan y Don, Bull Bay, Anglesey, LL68 9TE.
Badger
GP Ranchero
I should have a 100mm push rod in a box somewhere will check tomorrow.
Rich.
Got an NOS OE VW pedestal here Dave for the usual charity donation or for three if ewe can sort my breaks out as my tires look old their tyred.
I'll get in in the post Monday.
Thanks chaps, let me know what I owe y'all or will donate to RNLI to cover post. What brake bits do you need Flags? I've got T1 shoes and T3 hubs, drums and shoes if you need.
EDIT....was talking out of my elbow i.e. less reliable than my ar$e.
Is the woodruff key the same size as the one for the top pulley?  If so I have one of those too.
I couldn't resist poking a couple of your favourite bears Dave.
As said I'll post it on Monday.
What are you building?
Quote from: Flags on June 16, 2017, 11:18:03 PM
Just playing with a spare motor, maybe to throw in the Manx when I strip my own engine to clean out the rest of the RTV Silicon that Volkspares must've slathered it with when they 'built' it 15 yrs ago... :-\
Quote from: Buggybaggy on June 16, 2017, 10:23:04 PM
No sorry, much bigger.
#10
Breaks broke? Tyers tired? Axel bent? Whels buckled? Rims rubbin' (sorry but it makes my sh#t itch when people say 'rim' when they mean 'wheel's) ect ect ect ... Ha! You do know how to yank my chain! ;D
Bolt and washer just posted.
RNLI donation works for me  ;-)up
Quote from: Buggybaggy on June 17, 2017, 11:03:20 AM
Brilliant, thanks!
Testa
Hi Dave.
If your still after a 100mm fuel pump push rod I have one in my hand. Also I've got a woodruff key that is 20mm across the flat. If thats the one your after you can have them both.
Testa
Quote from: Testa on June 17, 2017, 04:54:42 PM
Hi Dave.
Testa
They sound just the job. Let me know what I owe you. ;-)up
