Rear view mirror
Started by wadsy, April 26, 2017, 06:11:51 PM
wadsy
Meyers Manx
I have a very nice brushed ally rear view mirror for sale, I imported it from the u.s for my buggy but then decided not to use it, I machined the rear of it so it sits at the correct angle on the screen, you will need a good way of bonding it as its quite heavy. I can send pics via mms if anyone wants them, easiest way. I want £60 for it posted in the uk.
Testa
I am interested but have my doubts as to weather it will fit. You say you machined the back off. Does this mean it's going to be a solid mount mirror without any adjustments for people's screen angle and different height drivers?
Testa
wadsy
Meyers Manx
It is adjustable still, when I got it you couldn't get enough 'tilt' on it to be able to see correctly so I machined the mounting face to the screen at an angle, the mirror still adjust like a conventional mirror, my buggy was a manx with a 14" screen and was perfect. I only used a double sided tape to mount it but was worried it would drop off so removed it, you can get proper mirror adhesive for glass but I have now sold my buggy so never pursued it. pm me your mobile number  and I will send you some pics.  :)
Testa
Did you get the pm I sent?
Still interested if you still have it.
wadsy
Meyers Manx
No pm received, yes I still have it.  :)
Testa
Sent again bud.
