While you've still got the paint out you may want to cut those jacking points off. They're useless on a buggy as you'll just lift the front up when you try to use them, plus they're ugly and they'll get in the way if you decide on side spats/pods. Jus' sayin'...
How did you end up with a late style front trans mount on a K&L pan?
Hi Dave... Yep they are coming off. They came with the pans and I thought might as well have them on. Then realised pods may go on, probably mean will
and pods have brackets with them to secure in the pan hollow section, and I will need bracing for seat belts and the roll bar. (Have a problem also in that I have 6 year old grandson who is desperate to get this on the road. I cannot get a definitive answer to the legality of a child of his age\size wearing a harness. Am told this will all most certainly have to be 3 point retractable with reels that operate at any angle, Angles and heights critical. Angle of across shoulder diagonal. Lap belt must cross leg bone not hip joint area and each mounting must meet the 3 tonne criteria). Long way to go with this as we are talking road legality with a child on board and not just iva. Floorpan... A mystery. Donor imported from South Africa 1995. Registered correctly with DVLA etc and has a legitimate V5C. However as the original was built at the Utenhage plant I cannot get any details from them or from VW museum at Wolfsburg. Chassis is swing\king\link pin so post 66? Shell id plate gives VIN number relating to 1975. I know that South African builds used anything available and often do not match normal expectation but this is unusual in the extreme unless it is a mix of more than 1 vehicle. Floorpans came from justkampers as supposedly correct for 1965 however when they arrived it looks like they were meant for left hand drive. cost a whopping £500
Transmission mount
Your guess as good as mine. I can see no evidence of non original external welding or internal welds that are not original. It has another oddity also but need to be sure this will not drop me in it so to speak
