I did not start out to build a buggy as i purchased an imported South African Griffen conversion convertible beetle. 1968 when it came off the production line and registered in the UK 1972. one of my friends owned this car for some years and it had been sat in the garden neglected and slowly rotting away. As i have owned a beetle since 1997 i decided i would purchase it and put it back on the road. The body was in a poor state, the hood was also in very poor state. It had king and link pin front beam with a rotten frame head. i removed the body and got to work on the restoration, first job was the rotten frame head. Now sporting balljoint frame head, i replaced the floors both sides. Then another project came in so this project got shelved.
2013 i decided i would build a buggy with the beetle floorpan and set about looking for a shell. I saw one on Ebay Mid Norfolk Moulders and bought it. 2 weeks later i drove down to Norfolk to collect the shell. i then shortened the chassis and started the project.
This project is not moving very fast as i travel with my job and as you can imagine other things also get in the way. Plus its a bit of fun building it.
i will add some photos when i find them all.
So project so far
Floor shortened
Roll cage built
Engine (well this was a pain as i acquired an 1800cc block pictures to follow)
windscreen fitted
Wheels (Weller)
Dropped spindles with Discs
Rear 4 stud drums
Steering column shortened and fitted.
Currently making a dashboard from Aluminium which i will no doubt spray with some metal flake
i have already found the forum very helpful and all the members are very friendly. I will add pictures of the project as and when
