Beach Buggy .Info
Welcome,
Guest
. Please
login
or
register
March 08, 2021, 09:33:37 PM
Beach Buggy .Info
Beach Buggy Help Zone
Beach Buggy Engine and Exhaust Help
(Moderator:
BEELZEDUB
Stuck in gear
Stuck in gear
This is a discussion for the topic Stuck in gear on the board Beach Buggy Engine and Exhaust Help.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Stuck in gear (Read 492 times)
africanbug
Namibia
Beamish Buggy
Stuck in gear
on:
May 20, 2015, 10:18:56 AM
Hi guys. It seems that the gearbox is stuck in a gear. It is still just a chassis with no engine, but if you push it around, you can hear it runs in gear. I tried to get it out of gear, but it does not want to. The selector rod moves freely, but it feels like it is stuck in a gear.
Please help.....
Logged
If all else fails, gas it....!!!!
Hunter
SDBC Moderator
Dorchester
CTR
Re: Stuck in gear
Reply #1 on:
May 20, 2015, 10:31:22 AM
The gearbox internals do turn when it is in neutral, try turning the output shaft with the wheels on the ground (as your able to push it around) does it want to move the chassis or does it turn freely?
H
Logged
(lwb Californian skooby powered in the wings)
africanbug
Namibia
Beamish Buggy
Re: Stuck in gear
Reply #2 on:
May 20, 2015, 10:41:53 AM
It wants to move the chassis.
Logged
Paignton, Devon
Re: Stuck in gear
Reply #3 on:
May 20, 2015, 10:49:37 AM
Does the gearstick feel like its selecting a gear when moved? Is it adjusted correctly?
Logged
evesham. 07757010432
Re: Stuck in gear
Reply #4 on:
May 20, 2015, 04:20:18 PM
easy way is to try and turn the input shaft by hand in neutral. if it does not turn tunnel rear plate off and operate the gear lever whilst looking at the selector linkage it may just be a loose grub screw on the selector input ( they should be lockwired )or a worn bush.
a broken failed rod front support bush by the lever gives excess play but still allows neutral selection ok.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Beach Buggy .Info
(Moderator:
BEELZEDUB
Stuck in gear
Login
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length.
