Hi,
I am nearing the finish of my build and noticed that there is no resistance in the clutch pedal. I took the engine off today and found that my clutch cover plate does not have a release ring in the centre. The clutch release bearing is the later type without pad.
Should there be a release ring on the cover plate? I have read that some are not meant to have it fitted.
Not sure why my clutch isn't working?.
Any help or suggestions much appreciated.
Regards
Richard
