March 05, 2021, 04:10:26 PM
oil change
This is a discussion for the topic oil change on the board Beach Buggy Engine and Exhaust Help.
Author Topic: oil change  (Read 269 times)
this user is offline Steve
  • Street Predator
on: February 03, 2014, 06:54:56 PM
after draining the oil and filling up with new, how do I do this (filling it up) I have seen a video where the cable from the coil was removed and let the engine turn over a few times until the oil light goes out
do I have to remove the cable from the coil, and I dont have a n oil light.
http://www.youtube.com/watch?v=LJD28DD4fT4
anything else I should do before I start it, after it sitting for so long.
this user is offline Big Clem
  • Colchester Essex
  • 66 prowler
Reply #1 on: February 03, 2014, 07:00:58 PM
Just crank it over a few times with ht lead from coil removed is what I normaly do  ;-)up might be wrong won't be the first time  :D
Reply #2 on: February 03, 2014, 07:34:33 PM
As Clem says just disable the ignition wire off or rotor arm out then spin it over or take the plugs out a squirt of oil down each barrel then spin it over to got the oil around and bores wet then refit the plugs and fire it up it will smoke a bit but thats no problem.
  • Street Predator
Reply #3 on: February 03, 2014, 07:56:59 PM
which would be the best since its been sitting for so long, plugs out or the other, last thing i want to do is damage anything
this user is offline ben_w
  • Leicestershire
  • Sidewinder
Reply #4 on: February 03, 2014, 08:50:56 PM
If its been sat for a while, I'd go with the plugs out, oil down the bore option
  • Street Predator
Reply #5 on: February 03, 2014, 09:26:33 PM
