Beach Buggy .Info
Welcome,
Guest
. Please
login
or
register
March 05, 2021, 05:01:44 PM
Beach Buggy .Info
Beach Buggy Help Zone
Beach Buggy Engine and Exhaust Help
(Moderator:
BEELZEDUB
Fitting camshaft
Fitting camshaft
This is a discussion for the topic Fitting camshaft on the board Beach Buggy Engine and Exhaust Help.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Fitting camshaft (Read 261 times)
Tone
Lowestoft
1966 volks rod
Fitting camshaft
on:
December 09, 2013, 06:46:39 PM
Hi just upgraded 1300 to 1641 now thinking about camshaft is this simple bolt in job or is there more to it any help would be good
Logged
Big Clem
Colchester Essex
66 prowler
Re: Fitting camshaft
Reply #1 on:
December 09, 2013, 06:56:43 PM
If you was going to change cam I belive it would be good practice to change pushrods and rockers as they wear to each other and whilst you have the block split you might as well go the whole way ie balance crank renew bearings ect
Hope its going well and look foward to seeing it in the flesh next year
Logged
Prowler inspired by turky juice !!!
Anglesey, North Wales.
Reply #2 on:
December 09, 2013, 07:02:05 PM
As you've got to split the engine case to get the cam out you'd generally only change it as part of a full rebuild. Any cam change would need new followers, uprated pushrods, stronger valve springs etc.
Logged
evesham. 07757010432
Reply #3 on:
December 09, 2013, 07:10:04 PM
rather than a new cam which needs new followers and whilst it is stripped down ideally needs a complete rebuild like Clem says, another option is to fit ratio rockers they are a bolt on up grade.
but any top end upgrade will put more stress on a worn bottom end and help it wear out faster not a problem with limited buggy miles but not ideal on a daily driver clocking the miles up.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Beach Buggy .Info
(Moderator:
BEELZEDUB
Fitting camshaft
Login
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length.
