March 07, 2021, 01:51:47 AM
Oil Pipes
This is a discussion for the topic Oil Pipes on the board Beach Buggy Engine and Exhaust Help.
Author Topic: Oil Pipes  (Read 1503 times)
this user is offline Hazel
  • Birmingham
  • mk1 GP
    • Beach Buggy Brummies
on: February 23, 2013, 09:35:02 PM
Can any one recommend someone/somewhere that could make up some oil pipes, for a remote oil filter?
this user is offline Peter
  • Kent
  • Manx2 UK-00-25
    • Your Buggy's
Reply #1 on: February 23, 2013, 09:58:05 PM
I can't recommend anyone your way, but you could try a hydraulics shop, truck
maintenance place, forklifts, garage, haulage fleet or somewhere like that.
Hydraulic hoses are used everywhere and the fittings for various sizes will be a standard, so
I should think there are several around you that you may have not thought of yet.
this user is offline AndyRobinson
  • ... and NO!!! Its not a hairdressers car! ;)
  • Leighton Buzzard
  • '65 Blue Sidewinder
    • www.print465.com - Great Value Print & Design
Reply #2 on: February 23, 2013, 10:15:09 PM
But they won't be cheap Hazel, remember the jubilee clip ends just don't cut it!
  • Birmingham
  • mk1 GP
Reply #3 on: February 23, 2013, 10:19:33 PM
They would, but would just prefer crimped pipe ends.
Where Dad works they use jubilee clips on 90psi air lines with no problem  :-\
  • Kent
  • Manx2 UK-00-25
    • Your Buggy's
Reply #4 on: February 23, 2013, 10:27:06 PM
That's as maybe I guess, and airlines have a habit of releasing the pressure on a more regular basis.
Whereas the oil pressure in your system will be up and constant.
Heat will also soften the pipework and the oil will also make the joint area slippery. All things
that will work against you when the fittings part company.
You are correct Hazel, but its best to use the screwed and properly crimped on fittings. Just because
of the environment its dealing with...
Peter :-[
this user is offline Hunter
  • SDBC Moderator
  • Dorchester
  • CTR
Reply #5 on: February 23, 2013, 11:20:34 PM
I think Aaron 1776 may be able to help with this one
H
(lwb Californian skooby powered in the wings)
this user is offline Chad
  • Kempsey, Worcestershire
  • Doon SWB
    • Doon Buggies
Reply #6 on: February 23, 2013, 11:40:13 PM
Hazel I did my own using Aerquip Hoses and pipework.
Really easy to be honest and cheaper than having some made up.
this user is offline BugDream
  • Beach Buggy
  • Chichester, West Sussex
  • Sidewinder
    • BugDreams Build Blog
Reply #7 on: February 24, 2013, 07:56:52 AM
As an example, I use these guys Hazel;
IES
Mainly because they're so close and convenient.
Not for the buggy though... A 50 year old tractor I look after  ;D
Slow progress...
  • Buggy Queen
  • Anglesey, North Wales.
  • Meyers Manx UK-00-002
Reply #8 on: February 24, 2013, 11:22:03 AM
Check online for your nearest branch of Pirtek, they run a fleet of mobile vans but you'd be best going to the counter and showing them what you need...
http://johnmaherracing.com/
  • Birmingham
  • mk1 GP
Reply #9 on: February 24, 2013, 08:37:24 PM
Thanks for the links guys, will have a look around  ;-)up
  • Doon SWB
    • Doon Buggies
Reply #10 on: February 24, 2013, 09:18:39 PM
There's a Pirtek in Oldbury Town
this user is offline Mantaray
  • Beach Buggy
  • Maidstone, Kent
  • Mantaray
Reply #11 on: February 25, 2013, 04:14:47 PM
I use pikey jubilee clips with no problem at all  ;-)up
1915cc 125Hp ;)
this user is offline muzzy01
  • leicester
  • lwb gt 2LTR 914 /lwb jas
Reply #12 on: February 26, 2013, 03:18:21 PM
hazel i used pirtek very good but expensive, ive had no problems since fitted
MUZZY
  • Kent
  • Manx2 UK-00-25
    • Your Buggy's
Reply #13 on: February 26, 2013, 07:50:11 PM
Quote
Pirtek.... A good name to remember ;-)up
this user is offline Zebethyal
  • Beach Buggy
  • Harrow
  • '65 SWB Volksrod Mk III
Reply #14 on: February 27, 2013, 08:57:15 AM
I also use Aeroquip for everything, oil, fuel, breather hoses, etc. no more expensive than Pirtek.
I can supply you with hose and most of the fittings if you are interested.
I can either do stainless over braided hose and annodised fittings, or blue push-fit hose and Nickel plated steel fittings, both hose types have a burst rating of over 20,000 PSI, the push-fit does not require any additional clips.
