David,
Thanks for that. I shall check the main front bearing for the bits you mentioned. To be honest, the inside of the engine looked pretty good. The shells looked ok and i couldnt see or feel any scoring on the crank. Would it be worth replacing them anyways or if the appear ok, leaving them?
The crank is going to need a little work anyway as the brass dizzy/fuel pump drive wheel is shot, so thats coming off and getting replaced. The barrels and pistons look ok, with no scoring etc.
Tempted to rebuild it and see if can get it running!
