April 20, 2021, 11:35:48 PM
Quality wire for buggy build
This is a discussion for the topic Quality wire for buggy build on the board Beach Buggy Electrical Help.
Author Topic: Quality wire for buggy build  (Read 542 times)
this user is offline Roman
  • Jr. Member
on: February 20, 2021, 02:10:25 PM
I am also starting to build a wiring loom. Thank you to all those who have posted such useful information here. I do have a question about the quality of wire to purchase? (Not a loom as I am happy to build my own).
I have seen RS components detail the specs of their thin wall auto wire which really helps, however they are more expensive than kit car solutions etc. I would rather pay for quality. Anyone have trusted supplies they would recommend?
Many thanks, Roman
  • Jr. Member
Reply #1 on: February 20, 2021, 02:17:54 PM
Example!
this user is online Manxdavid
  • Buggy Queen
  • Anglesey, North Wales.
  • Meyers Manx UK-00-002
Reply #2 on: February 20, 2021, 02:24:59 PM
I usually strip down lengths of 7 core trailer cable for most circuits on a buggy. ;-)up
Most of the caravans on driveways round here don't move from one year to the next, they hardly need lights ;D
Photos printed on genuine ILFORD® paper, sent from a Commodore VIC 20.
Reply #3 on: February 20, 2021, 02:25:52 PM
I have often found RS to be overpriced - sure, quality is generally good, but you will be paying top dollar for the RS association.
For general wiring stuff that we do here, we buy 100m rolls which can work out quite expensive if making a one off loom, especially as you would need a roll for each colour. For some of the wiring, where you only need a few meters of a particular colour, or even the cables with a striped identifier, I would suggest to make a list of the lengths you want and search for a thinwall automotive cable supplier through the likes of ebay as they will sell it by the meter rather than the roll. Buy what you can in one hit to save on the postage. For very heavy cable and audio cable, yes, spend a bit for some good quality, but the general purpose stuff, I`ve not noticed much difference between suppliers.
this user is offline Hugh
  • North Herefordshire
  • Mantaray Mk II
Reply #4 on: February 20, 2021, 02:50:14 PM
Snoopy kindly steered me to these suppliers for re-wiring the MantaRay:
https://www.autoelectricsupplies.co.uk/
this user is offline Chad
  • Kempsey, Worcestershire
  • Doon SWB
    • Doon Buggies
Reply #5 on: February 21, 2021, 10:46:39 AM
I agree with Hugh. I have done a lot of cost comparisons across the wire suppliers and AES are generally good value for money and good quality cable too which you can buy by the metre or in a roll.
If you are looking for other parts like cut off switches, fuseboards or rolls of single colour wire then Beal.org.uk is so worth a look too.
And buy thin wall cable.
  • Bourne, Lincs
  • FF Buggy LWB
    • Zip Buddy
Reply #6 on: February 21, 2021, 12:48:22 PM
Agree with all the above except I got let down by AES - they lie a lot too. Vehicle Wiring Products are great for cable and their prices include vat on the site (same price as AES).
this user is offline pepsi81
  • Whitehaven, Cumbria
  • Purple GP 2
Reply #7 on: February 22, 2021, 09:52:28 PM
RS are a supplier for us. Standard is good, price isn’t. I’d go with Chad’s recommendation.
Paul
  • Jr. Member
Reply #8 on: March 05, 2021, 11:34:52 AM
Anyone used marine wire and fuse boxes? As the quality seems good, copper tinned bus bars, copper tinned cable etc.
Also has anyone used the Blue Sea fuse box set up, linked with relays. Will post diagram later for clarity.
this user is online Doon L001
  • Nr Leek Staffordshire
  • DOON LWB
Reply #9 on: March 05, 2021, 01:02:54 PM
I used busbar units from a marine chandler's for my earthing blocks. Really good quality and can be fitted with covers
  • Jr. Member
Reply #10 on: March 05, 2021, 04:43:45 PM
Thanks for all the feedback.
Has anyone mounted their fuse box and relays close to the battery? The Blue sea systems fuse box uses one short wire from the positive side of the battery, then connects with relays and switches via fuse box.
Any thoughts much appreciated.
  • DOON LWB
Reply #11 on: March 05, 2021, 06:16:37 PM
Logically the nearer they are to the battery the shorter the unfused sections of cable. Ditto with the relays, the unswitched, or live, section of high power cable is as short as possible.
So long as they're accessible in case they need changing near the battery makes some sense.
I did fault find on s friends beetle once that stunk of burned out cable and he had stopped it bursting into flames by lifting the back seat and disconnecting the battery.
He'd fitted air horns and run the power to under the bonnet along the floor.  Fuse and relay right next to the airhorns. Cable just on the floor and it failed just after moving his seat, I'll leave you to work it out.
If lots of ifs here like not just dumping the cable on the floor bit if the fuse had  been next to the battery it would have been a lot less frantic and he wouldn't have got towed home
