April 20, 2021, 11:34:23 PM
Getting a good earth/ground
This is a discussion for the topic Getting a good earth/ground on the board Beach Buggy Electrical Help.
Author Topic: Getting a good earth/ground  (Read 735 times)
this user is offline neilpop
  • Jr. Member
  • Walderslade
  • Sidewinder
on: November 21, 2020, 04:07:08 PM
Hi, bit of a basic question but...
I get the concept of the chassis and engine/gearbox making a common ground but I wanted to check is it best to have the negative from the battery connect to the chassis and then a further cable from the chassis to the gearbox to be certain of a good earth?
Thanks,
Neil
this user is online Doon L001
  • Nr Leek Staffordshire
  • DOON LWB
Reply #1 on: November 21, 2020, 05:04:06 PM
With a fibreglass shell you can't have enough earth connections. A metal body normally routes the earth to lights etc.
I have put earth blocks near every set of electrics, 2 by engine, 2 under dash and 2 more under bonnet. These connect to the nearest chassis point and all lights etc have individual cables to the blocks
I used marine quality from a ship's chandlers
  • Jr. Member
  • Walderslade
  • Sidewinder
Reply #2 on: November 21, 2020, 06:31:47 PM
A resounding yes then! Thank you!  ;-)up
Reply #3 on: November 22, 2020, 08:32:44 AM
It`s a yes from me and go a step further... Chassis ground to gearbox and VW did it for decades and then a ground cable from gearbox to engine itself. A good, fully charged, battery should give a voltage reading of a tad over 13volts.  ;-)up ;-)up
Reply #4 on: November 22, 2020, 09:34:20 AM
tried a different approach on the kango battery earth to gearbox and 2 insulated buzzbars for the rest back to the battery neg so in theory the current does not flow through the pan accelerating corrosion when used over winter with salt around. The pan will still be negative as mounted electrical items are not dual pole insulated and the clutch, choke and throttle cables will earth to pan.
  • Jr. Member
  • Walderslade
  • Sidewinder
Reply #5 on: November 22, 2020, 12:50:51 PM
Thanks guys, appreciate all your feedback and advice  ;-)(-;
