Dug this out today... Can anybody on the forum put it to good use
Have described ths as a " 4 into 1 " Header system. The four pipes, suitable for Type 1 crankcases and anything with identical exhaust outlet placings, merge to a 3 bolt single flange type outlet. To this you can bolt a single silencer or with an adaptor pipe fit two cannon style silencers. Has manifold hot pipe connections if needed. If not blank off.
This merged header is brand new and has never been fitted or used in any way. I have a suitable flange gasket somewhere that I will dig out and supply bolts, washers & nuts for the flange.
Has it`s made in Taiwan sticker still on it. Has the original "transit paint" on it, (as described by the major retailers we all know). but this is just a covering. Has some very fine rust speckling in places but nothing that would not disappear with a bit of emery cloth.
£50.00 plus a bit toward postage... Say £7.50 and I will cover the rest. (It`s a large and bulky item).
Cheers for now Paul
