April 11, 2021, 10:10:27 AM
Tow bar height
This is a discussion for the topic Tow bar height on the board Beach Buggy General Help.
Author Topic: Tow bar height  (Read 1390 times)
this user is offline mk4buggy
  • Buggy Baron
  • Cheshunt, Herts
  • Mk8 Volksrod LWB
on: October 18, 2020, 09:45:53 AM
I have a trailer towbar fitted at the rear which is giving me a measurement from the ground to the centre of the ball of 300mm, the recommended height should be between 350mm and 450mm, what heights are the towbar ball on other buggies.
this user is online Doon L001
  • Nr Leek Staffordshire
  • DOON LWB
Reply #1 on: October 18, 2020, 11:25:20 AM
I would think that's pretty critical on a car with all the weight at the back.  But rather than aim for a specific height I would aim to get whatever you are towing level or at least not pointing down at the towball.
Guess it's only a short light trailer with small wheels you are towing rather than a long horsebox and the force down on the hook is what makes the difference
  • Buggy Baron
  • Cheshunt, Herts
  • Mk8 Volksrod LWB
Reply #2 on: October 18, 2020, 11:40:58 AM
Yep just a small fibreglass trailer, the towbar frame was designed to fit a vw trike and fits the same as the normal towbar, u clamps on the torsion bar tubes and to the frame horns, just can't see any other way of raising the height other than getting the towbar redesigned.
Reply #3 on: October 18, 2020, 02:27:15 PM
I set my Buggy tow bar at 40cm from the ball centre to the ground
Which is exactly the same height as my Freelander, my T4, My Audi, my Vauxhall and I have never had any nose weight or jockey wheel gounding out issues when towing
  • Buggy Baron
  • Cheshunt, Herts
  • Mk8 Volksrod LWB
Reply #4 on: October 19, 2020, 04:19:36 PM
Cheers Dave  ;-)up
