April 20, 2021, 10:55:38 PM
Indicator Flasher Unit
This is a discussion for the topic Indicator Flasher Unit on the board Beach Buggy Electrical Help.
Author Topic: Indicator Flasher Unit  (Read 441 times)
this user is offline Cornishdave
  • Full Member
  • Hustler
on: October 15, 2020, 05:47:37 PM
Hi. I have been advised that I need to source a new indicator flasher unit as the one currently fitted is for a 3 light set-up - front, rear and repeater - and I do not have a repeater. As a result it is flashing too fast and the fuse keeps blowing.
There are loads of units online but I can't seem to find any that specify that they are for a 2 light set-up with no repeater.
Can anyone please help?
Reply #1 on: October 15, 2020, 07:09:13 PM
are you using the beetle warning light in the speedo as it is a reverse feed positive to the outside of the holder and earth out through the indicator switch. A side repeater should make no difference if it is a no load led can or a 21w bulb type.
  • Full Member
  • Hustler
Reply #2 on: October 15, 2020, 08:12:28 PM
Thanks Snoopy that is very helpful.
I do have a warning light but it is more of a bulb dangling below the dash at the moment!
I will pass your comments on to my mate and fingers crossed progress will be made!!
