Beach Buggy .Info
Welcome,
Guest
. Please
login
or
register
January 25, 2021, 12:53:57 AM
Beach Buggy .Info
Beach Buggy Help Zone
Beach Buggy Engine and Exhaust Help
(Moderator:
BEELZEDUB
Gear box clutch shaft movement
This is a discussion for the topic Gear box clutch shaft movement on the board Beach Buggy Engine and Exhaust Help.
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Gear box clutch shaft movement (Read 520 times)
Sam101
Kingsbury Episcopi
UVA Sandrail
on:
October 12, 2020, 05:52:01 PM
Evening all , a few weeks ago I stripped the engine off and rear axle / gear box . The engine came off easily , no excessive force needed .
The shaft that comes from the gear box to the clutch has movement in it . Probably about 5mm sideways / up down etc . No in and out .
Is this meant to be or is it a new bearing job ?
I don’t intend to do a full strip and was hoping not to have to open it , but if needs must .
Cheers Sam
Logged
Sam101
Kingsbury Episcopi
UVA Sandrail
Re: Gear box clutch shaft movement
Reply #1 on:
October 12, 2020, 06:05:52 PM
Also , as a side note , can anyone recommend anyone who does a full rebuild , as I have another AB swing axle box stripped ready for a rebuild , but it’s waaaay out of my league .
I am down south west but happy to ship it for a quality job .
Cheers Sam
Logged
Anglesey, North Wales.
Reply #2 on:
October 12, 2020, 08:05:21 PM
It'll be fine, the nose of the input shaft is supported by the pilot bearing in the flywheel bolt. A little play is normal.
Logged
Sam101
Kingsbury Episcopi
UVA Sandrail
Reply #3 on:
October 12, 2020, 09:24:38 PM
Thanks for that ManxDavid , this whole level of mechanics is new so was always let to believe that shafts should be rigid / no play or movement .
I will continue as planned then.
Cheers Sam
Logged
Speedy
Kidderminster Worcestershire
Manx
Reply #4 on:
October 12, 2020, 09:32:02 PM
As David says the first motion shaft sits in spigot bearing in flywheel nut so when it's all bolted up there will be no play
Logged
Work hard : play harder
evesham. 07757010432
Reply #5 on:
October 13, 2020, 08:02:29 AM
for arebuild on a box Bear Motorsport up by the NEC.
Logged
Paignton, Devon
Reply #6 on:
October 13, 2020, 08:10:22 AM
Quote from: snoopy on October 13, 2020, 08:02:29 AM
for a rebuild on a box Bear Motorsport up by the NEC.
I bought a brand new "Rancho" box from Heritage for a fraction of the price that "Bears" quoted me to repair my old one - Shop around
But as others have said, that shaft is supported at the front by an inner bush, so wouldn't panic just yet
Logged
Reply #7 on:
October 13, 2020, 08:39:25 AM
If it was quiet, changed nicely and didn't jump out of gear then it's fine.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Beach Buggy .Info
(Moderator:
BEELZEDUB
Login
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length.
