The remote oil filter is piped through the inlet manifold beneath the carb, which should help, but I'm not sold on the Holley anyways, so thing it'll be getting a pair of DRLA40's at some point.
The general feeling among the Corvair boys in the states is that it's not a great option, especially as you say, in the colder areas.
The standard setup on the 140 is weird anyways, as it has 4 Rochester carbs, but two are primary, and the other two are secondary, not four identical carbs.
