What about switchback led bulbs, connect one side to a live and the other to the indicator circuit, will give you a constant white light which goes out when the indicator is usedTtfn Glenn
Quote from: 93fxdl on September 26, 2020, 08:43:13 PMWhat about switchback led bulbs, connect one side to a live and the other to the indicator circuit, will give you a constant white light which goes out when the indicator is usedTtfn GlennThat sounds perfect. Where would I find something like thst.? eBay maybe? I must admit to being a real dinosaur and I've never heard of such black magic.
Would a beetle indicator switch with the parking light function work the indicators as normal but use the parking wires left and right to turn off a relay powering the running lights you would need diodes where the feeds to the bulb meet to stop feed back, just a thought.
