January 25, 2021, 12:28:33 AM
Head spacer
This is a discussion for the topic Head spacer on the board Beach Buggy Engine and Exhaust Help.
Author Topic: Head spacer  (Read 427 times)
this user is offline hustler
  • Buggy Addict
  • hayling island, hants
  • Beamish buggy
on: August 25, 2020, 01:35:37 PM
Hi all,just stripped a 1600tp and between the cylinder heads and barrels were thick spacers.What are these for,never come across them before.
Cheers
  • northants
  • SWB Rat
Reply #1 on: August 25, 2020, 01:43:42 PM
They are usualy fitted to the bus engines to drop the compression ratio a bit but you do not need them on a buggy engine. You just need to check you have enough clearance between the pistons and heads on rebuild and fit bottom cylinder shims if need be  ;-)up
  • Buggy Queen
  • Anglesey, North Wales.
  • Meyers Manx UK-00-002
Reply #2 on: August 25, 2020, 02:25:58 PM
Some replacement heads were supplied with them. Original VW heads had a raised ridge around the circumference but on some pattern heads the surface was completely flat so these shims were needed to get the correct deck height.
If you've got that ridge then as Rob says they're to lower the compression do not needed on s buggy.
  • Buggy Addict
  • Beamish buggy
Reply #3 on: August 26, 2020, 05:46:53 PM
Thankyou very much guys.That was very helpful.Cheers ;-)up
