January 25, 2021, 12:46:27 AM
Spark Plugs
This is a discussion for the topic Spark Plugs on the board Beach Buggy Engine and Exhaust Help.
Author Topic: Spark Plugs  (Read 1264 times)
this user is offline Hunter
  • SDBC Moderator
  • Dorchester
  • CTR
Reply #15 on: August 27, 2020, 02:34:15 PM
Still cleaning my plugs....Top one still as it came out, bottom one has been in the cleaner
Some of you guys might remember this bit of kit.
H
(lwb Californian skooby powered in the wings)
Reply #16 on: August 27, 2020, 03:29:52 PM
Running a bit rich there H, cleaner works well.
this user is offline Hugh
  • North Herefordshire
  • Mantaray Mk II
Reply #17 on: August 27, 2020, 03:47:20 PM
Is it a mini sand blaster ?
I use a wire brush till it looks better than it started...but there's something satisfying about an official looking magic box particularly as it implies it does the job properly.
this user is online Doon L001
  • Nr Leek Staffordshire
  • DOON LWB
Reply #18 on: August 27, 2020, 05:05:54 PM
Funnily enough just done mine but not so high tech.
Brass brush then flush with WD-40
Hugh, worth investing in a small brass brush for plug cleaning rather than a wire brush, not sure why but just sort of remember you should
  • Mantaray Mk II
Reply #19 on: August 27, 2020, 05:51:11 PM
Dave I know you are right because 'brass brush' rings a bell with me too !
It must be a wire brush is too harsh for the tip material.
  • SDBC Moderator
  • Dorchester
  • CTR
Reply #20 on: August 27, 2020, 06:01:20 PM
Only fired it up about 2yrs ago for a very short time just to initially run it, before I took it off and put the spare 1641 in so's I can do a clean up and check over and a really good service as its been on the buggy for the previous 7 years without anything major apart from oil changes mainly.
H
Reply #21 on: August 27, 2020, 07:21:00 PM
Certainly do . . .  I was Technical Manager at Halfords when I was 17 and sold shedloads of those - still got mine too
Brilliant bit of kit   ;-)up
this user is offline Validwarlord
  • Full Member
  • Nottinghamshire
Reply #22 on: August 28, 2020, 05:02:15 PM
Hi
I have one of those as well what sand/gritting stuff are you guys using?
Dave
Buggies never get old the owners do!!!
this user is offline Jaysons Dad
  • Buggy Baron
  • Sutton Coldfield, West Midlands
  • 1961 Beaujangles Can Am
Reply #23 on: September 22, 2020, 06:09:56 PM
Can anyone recommend either a source of decent (or half decent plugs), or just the model/type of plugs I should be seeking out for:
1] 1600 beetle engine
2] Type 4 engine
Snoopy tells me there was a Fake Britain (BBC1) program last week on rip off ngk plugs - but I suspect the whole spark plug market is riddled with crap stuff. As ever I don't mind paying a few quid more but not if its just over blown marketing.
Type 4 NGK BR6ES Bosch WR7CC RN5C
Definitions -
  • Mantaray Mk II
Reply #24 on: September 22, 2020, 08:16:48 PM
Thanks sir.
