Again thanks Paul. Your steer is backed up by what I've now read about these particular plugs.
Spark plug Bosch W8 CC fits:
Type 1 engines 10.1992 and later
Type 4 engines
CT/CZ engines 1980 (engine nr. 065011) and later
Thread size: M14 x 1.25
Thread length: 19 mm
Wrench size: 21 mm
Gap: 0.8 mm
Heat range: 8
For each spark plug, the degree of heat is mentioned, a rule of thumb to determine which degree of heat you would need is as follows. With NGK, the higher the value, the colder the spark plug and with Bosch, the higher the value, the warmer the spark plug. You cannot compare the values with each other, NGK and Bosch have their own value system in which the heat level 5 of NGK is equal to the heat level 8 of Bosch.
