March 05, 2021, 04:13:56 PM
Fan bolt torque
This is a discussion for the topic Fan bolt torque on the board Beach Buggy Engine and Exhaust Help.
Author Topic: Fan bolt torque  (Read 573 times)
  • Edit Enabled
  • Leeds
  • Mk2 Volksrod
on: August 09, 2020, 12:42:10 PM
Putting the alternator and fan back together.
The book says 43lb foot for the fam bolt. But my socket is a 3/4 inch drive snd my torque wrench 1/2 inch.
So how tight is 43lb foot?
Must have done it OK last time when I put the new fan on.
Reply #1 on: August 09, 2020, 01:12:11 PM
Best put the torque wrench in the vice and pull it to get the feel Of 43 lbs ft then using the same length bar you should get pretty near with your pull on the fan slightly tighter is better than a bit loose.
  • Edit Enabled
  • Leeds
  • Mk2 Volksrod
Reply #2 on: August 09, 2020, 01:56:45 PM
Cheers Snoopy
this user is online Zip Buggy
  • Bourne, Lincs
  • FF Buggy LWB
    • Zip Buddy
Reply #3 on: August 09, 2020, 03:37:34 PM
No much help now Steve, but I bought a 1/2inch up to 3/4inch adapter to use the big sockets on my 1/2inch torque wrench.
this user is offline IDA
  • Buggy Obsessed
  • CHICHESTER
  • Mk2 Rat and LDV
Reply #4 on: August 09, 2020, 05:09:29 PM
In the vice and 3/4 bar and socket in the back and FT ..
this user is online Doon L001
  • Nr Leek Staffordshire
  • DOON LWB
Reply #5 on: August 09, 2020, 05:40:12 PM
1/2 to 3/4 converters and vice versa  are cheap as chips and you will need it again
  • Edit Enabled
  • Leeds
  • Mk2 Volksrod
Reply #6 on: August 09, 2020, 08:37:23 PM
Well I ended up putting the torque wrench on the pulley end of the alternator and used a fixed socket wrench on the fan end. Turned the fixed wrench, and the torwue wrench acted as a wedge to stop the alternator and fan rolling. Seemed to get it well tight before the torque wrench clicked in.
Seemed to be tightening up nicely from fan end. Doubt it can be guaranteed to tighten both ends equally but I'm confident it'll be good.
  • DOON LWB
Reply #7 on: August 09, 2020, 10:22:21 PM
That was a good idea, wish I'd thought of it
