Hi all, I’ve had my SWB GP mk1 1600 a week. Been starting immediately each day.
Strange thing happened today though. I put the battery on charge overnight as it was getting a little lazy and when I went to start the buggy today it was dead - despite the battery being fully charged at 13.1v. Turned the key in the ignition and nothing happened. No lights, no start. Nada.
It’s weird because it’s started immediately each day this week I’ve had it.
Checked fuses and they’re ok. Got the same voltage as the battery on the starter motor, at the voltage regulator (top two connectors) and at the first input to the fuse box with a 16a fuse (RH fuse looking to front of car - fuse box on bulkhead).
Took the ignition barrel and switch out of the dash and if I put a live feed from battery to the IGN connectors then each of them respond. If I give 12v to the SR connector the starter motors fires. Like wise if I give 12v to the voltage gauge the needle starts to move.
I do not have voltage coming out of the voltage regulator going to the generator.
The red wire coming from the fuse box to the ignition labelled BAT has varying voltage from 0 to 9v but never 13v...
Did I somehow fry something putting my battery on charge with disconnecting the terminals?
Where I removed the fuse to check is where I have battery voltage.
Any advice appreciated I’d love to go for a Sunday drive!
