Hi Spencer,
I'm one of the 2 guys who run FF buggies. If you message us through the Facebook page I can send you some videos of the flakes you are interested in, I have samples of all the ones we do.
https://www.facebook.com/ffdunebuggySplinesGet your buggy built, roll it before setting your splines, you will need to set this for your final weight and this will really depend on the weight of the components you use in your build.
WheelsThere are less choices available on the 4 stud wheels. Your best bet is to have a look on Cool Air VW and see if there are and 4 stud that take your fancy
https://www.coolairvw.co.uk/category/shop-by-vehicle/buggy-baja-and-trike/buggy-wheels/buggy-baja-buggy-and-trike-wheels/?per_page=10&page_no=2&sort=cSortRelevancyYou will have far greater choice of wheels in either porsche 5 stud or Chevy/Jag 5 stud patterns and are not limited to VW parts suppliers only. For example
https://www.northhantstyres.com/main-wheel-page.phpThe Buggy stylesEast Coast supply the GT Buggy is a GP style buggy where the majority of the stretch from SWB is in the rear arches.
The FF was reshaped so the stretch is hidden into the rear curve.
At FF Buggies we put tubes into the undersides of our tubs for you to run wiring down. We also blend in the backing gel colour into our fibreglass resin so there is constant colour through the shell. The same colour is used in the underside flow coat.
There is also the option of a removable hard top roof with the FF, which can be provided in flake.
FlakesOur flakes come in 4 different types:
- Straight/Rainbow - This is a single colour flake
- Holographic - This is 80% single colour with 20% silver hologram colour changing flake mixed in
- Chameleon - 100% pure colour hologram flake
- Blends - These are a mixture of flakes many of which are black based with colour mixed in
We can also supply the same flakes as East Coast, for a £50 premium or any of the Flake King range for £100. Please note the yellow Ibbotson flakes also have a £100 premium due to the cost of those specialist flakes.
