Don't like to disagree with David but I tried venting to twins with K&Ns and all it did was oiled up the carbs and ran like poo
If you have a VW standard filter then venting there is absolutely the way to go
I have put quite an elaborate venting system on but debatable whether it is really necessary. Probably just as well to leave as it is
One question, what pulley are you running? The standard one has a thread that pumps air into the case, many aftermarket pulleys, if they have a thread at all, have a really shallow one that doesn't have the proper effect.
