Take the gudgeon pin out the piston, put the piston in the barrel using a ring compressor or tin can suffice with a jubilee clip and then refit the assembly,
piston has now been removed.....:-)i’ll have a bash tomorrow now at popping it back in if i can find a jubilee clip big enough
hi - so presumably after the first ring is inside the bore do you slide the tin can down ?...or will the piston tube move the can down ?....thanks
Quote from: grissley on May 02, 2020, 01:50:35 PMTake the gudgeon pin out the piston, put the piston in the barrel using a ring compressor or tin can suffice with a jubilee clip and then refit the assembly,Bloody Hell, I never thought I'd find myself agreeing with Grissley...... Nurse!!!
