May 29, 2020, 06:03:34 PM
Bracket and bush
This is a discussion for the topic Bracket and bush on the board Parts Wanted.
Author Topic: Bracket and bush  (Read 187 times)
this user is offline phillmore
  • Jr. Member
  • Bristol / Pembrokeshire
  • Gp mk 3
on: April 05, 2020, 05:22:20 PM
Hi all,
Has anyone got the bracket that mounts on the left side of the tunnel, to hold the pedal assembly. I have the throttle arm, outer cover and the rest of the pedal assembly.
Thank you.
Old School.
this user is online snoopy
Reply #1 on: April 05, 2020, 06:01:21 PM
there are a couple here will have a dig I know one has the arm stop bracket peg missing so needs a bit tacked on or a screw others will be fine. should go in an envelope with a bit of card.
  • Jr. Member
  • Gp mk 3
Reply #2 on: April 05, 2020, 06:14:13 PM
Hi Snoopy,
Just came back in from the garage and have found a bracket amongst my old bits. Thank you for offering to look.
Old School.
Reply #3 on: April 05, 2020, 07:05:17 PM
Good to see I am not the only one who looses bits, think the shed is haunted and stuff moves after I put it down  ;D
