May 28, 2020, 02:57:00 AM
Starter bush replacenent
This is a discussion for the topic Starter bush replacenent on the board Beach Buggy General Help.
Author Topic: Starter bush replacenent  (Read 397 times)
  • Edit Enabled
  • Leeds
  • Mk2 Volksrod
on: March 14, 2020, 03:25:11 PM
How do I fit a new starter motor bush?
I've drifted the old one out from the flywheel end. But how best to get the new one in without manglung it?
Also, can it be put in fton the flywheel end, or must it be put in from the starter end?
Thanks.
Reply #1 on: March 14, 2020, 03:58:03 PM
Dead easy mate - have a look at my build thread
http://www.beachbuggy.info/index.php/topic,20.msg18506.html#msg18506
Top tip - or should that be Top tap?
That little bush can be a tight fit in the bellhousing, but comes out in a matter of seconds if you run a tap through it and wind it out
  • Edit Enabled
  • Leeds
  • Mk2 Volksrod
Reply #2 on: March 14, 2020, 05:42:37 PM
Sorted. ;-)up
