March 04, 2021, 07:15:54 AM
Quieter exhaust suggestions please
This is a discussion for the topic Quieter exhaust suggestions please on the board Beach Buggy Engine and Exhaust Help.
Author Topic: Quieter exhaust suggestions please  (Read 971 times)
this user is offline Lacanau
  • Newbie
on: January 19, 2020, 11:44:58 AM
I've been using dual cannons on my 1300 but as I get older I would really like something that produces less noise. Anyone know a source of similar style but quieter, ideally a bit shorter as the current ones stick out about 5 inches beyond rear bump bar, in stainless perhaps.
this user is offline pepsi81
  • Whitehaven, Cumbria
  • Purple GP 2
Reply #1 on: January 19, 2020, 03:43:57 PM
Mike ‘Beezledub’ Hausmann is they only guy I’ll recommend. Within reason he can make a style of your choice. All in s/s. Not  cheap but definitely the best .
Paul
Reply #2 on: January 19, 2020, 04:36:16 PM
Youcould fit baffles in the cannons and shorten them or cut them off and fit 2 bike cans or a decent 4 into 1 which helps the hp output
this user is online Doon L001
  • Nr Leek Staffordshire
  • DOON LWB
Reply #3 on: January 19, 2020, 05:08:46 PM
What Paul said
Mike's exhausts are the way to go.
Let the engine breath properly as well.
Cannons look pretty but aren't the best exhasts
this user is offline Dipsy Deb
  • Beach Buggy
  • Gwent
  • LWB Rat
Reply #4 on: January 19, 2020, 05:44:38 PM
Hi I put baffles in mine, very cheap and make it quieter, thanks to Paul's advice. Deb
  • Purple GP 2
Reply #5 on: January 19, 2020, 08:32:35 PM
My exhaust. Runs loads better via Mikes exhausts
  • Newbie
Reply #6 on: January 20, 2020, 02:11:47 PM
Thanks all for suggestions. Mike ‘Beezledub’ Hausmann sounds like the man. For a quick fix, does anyone know if the VW Heritage Empi baffles fit or is it a case of knocking something up out of bits and pieces.
Reply #7 on: January 20, 2020, 03:03:10 PM
You can make your own but you can get a pair cheap as chips of flea bay.  Just measure inside diameter of your cannon outlet. Match this diameter with baffles of same o\d or as close as available. You will find what you get either slips straight in or you made need a bit of tweaking.
I have temporary cannons on my buggy build and the baffles quieten down somewhat but don`t expect miracles.  :D :D
  • Henlow, Bedfordshire, UK
  • FF LWB
Reply #8 on: January 20, 2020, 11:39:20 PM
I fitted baffles with exhaust wadding wrapped round them and the volume went from 119db @3000 rpm to 103db.
However, there was a noticeable drop in performance and the general driving experience wasn’t the same, so I have just removed them.
  • Purple GP 2
Reply #9 on: January 20, 2020, 11:57:31 PM
Like I said. Quality counts. Mikes exhausts not only look good but are tuned to suite the engine  ;-)up ;-)up
